Tape not sticking
Old 06-14-05, 01:35 PM
Tape not sticking
Im papering my seams at the moment and I find that after the first coat of mud the paper isnt stuck down in some places. Do you have any ideas what I can do?
Shall I rip it off and start over??
Thanks
Old 06-14-05, 02:03 PM
You may be able to slip some mud under the tape and get it to stick. If not only remove what you need to and re tape.
Old 06-14-05, 02:05 PM
Ok thanks, I tried that a little while ago so Im just hoping its going to dry ok. There is another piece which seems not to be sticking down the centre, and Im just going to wait for that to dry to see if its ok. Thank again
Old 06-14-05, 07:23 PM
If it is a corner joint it will probably be OK. If it is a flat taped joint and the paper is bulged out you will most likely need to re tape it. Like you said give it time to dry first as there is always enough work to do with out making more.
