Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
electrical outlets pulled through sheet rock
Old 06-22-05, 07:40 AM
Canda
An electrical outlet has pulled through the sheet rock wall. The outlet was not supported, the only support seems to be the toggle screws holding it to the underside of the wall. I need some guidance to repair the wall around the outlet and suggestions to replace the outlet with something more sturdy.
Old 06-22-05, 12:11 PM
The type of box is refered to as a "tiger" box and is commonly used when an additional outlet is needed afetr the wall material is installed.
You can reuse this device in a new location, or locate a stud, cut a larger hole and set a new work box.
Old 06-23-05, 12:40 PM
Canda
progress of sorts
snoonyb,
thanks for your help. I went with a new box with a side flange to attach to the stud. I plan to hat patch the old hole with the cut out from the new one. The new outlet sits about 1/4 inch from the wall. The only thing I can think of is to use quarter-round to frame it (is this finger nails on a chalk board to some?). Would there be a product that has a flange but will set flush against the wall?
Old 06-23-05, 06:14 PM
The box you selected is also available w/o a reveal. Or you could use a 4s box which has plaster rings that reduce to a single device, from flat to 1 1/4" wall thickness.
