ceiling sagging
momme's Avatar
07-10-05, 07:15 PM   #1
ceiling sagging
Trailer home - my ceiling in the kitchen is starting to sag, there is a seam in the middle where it is sagging. It was probably leeking on the roof. Any suggestions on fixing the sag? Thank you!!!
awesomedell's Avatar
MO
07-10-05, 08:17 PM   #2
First fix the roof, might get away with a layer of silvercoat, but also may need to be covered with either new shingles or metal roofing. Than most likely you'll have to pull down the ceiling & replace with new drywall.
momme's Avatar
07-11-05, 04:57 AM   #3
sagging ceiling
Thanks for the information!!!!
marksr's Avatar
TN
07-11-05, 06:08 AM   #4
You may be able to install extra screws to draw the ceiling up. Prop the sagging part up first. Be sure to use decorative washers or the screw will go through the celotex. If you rehang the ceiling with drywall you may need to beef up the roof trusses to handle the extra weight.
momme's Avatar
07-11-05, 05:37 PM   #5
sagging ceiling
Thank you!!!!
