Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Painting Acoustical Ceiling Tile - bad idea ?
Old 08-02-05, 07:58 PM
or not ?
I noticed the cheap flat white paint on the tile can get dirty very fast.
So before installing, I was going to apply a pure acrylic finish.
The ceiling is being installed in a basement bathroom with high potential for mold, dampness.
Will this painting affect the sound dampening characteristics of the tile ?
Any other problems to consider ?
Old 08-03-05, 07:38 AM
Use a satin latex enamel. It is less likely to show fingerprints from installation and does a better job of repelling moisture than flat will. It will probably make the panels less sound absorbent - but I doubt you will notice.
Old 08-03-05, 08:32 AM
Thanks....
and I'll use a mini roller with stiff foam to avoid penetrating too much...that should help.
Old 08-03-05, 10:30 AM
If you don't apply enough paint for even coverage it may look splotchy.
Old 08-14-05, 08:27 AM
I'm thinking of doing this..
Does it look OK, if you do a good job painting it? I want to paint the staple up ceiling tile which has been in place at least 30 years. I was thinking of using a roller, it would not be feasible to spray paint it. My husband wants to remove and replace, but after 4 months solid of building a bathroom, I just don't think it is worth the effort.
Mostly I'm concerned that it will improve the look of the rec. room.
Old 08-14-05, 10:04 AM
cilla2004
Painting the ciling tiles will certainly brighten them up. It may take 2 coats if they are especially dingy. If there are any water stains be sure to prime them will a stain blocker. A 3/4" [or bigger] nap should apply the paint fine.
