08-10-05, 08:59 PM
wayne1968
inside corners drywall???
What is the best way to finish inside corners? Tape or corner bead? Do I do the same between the walls and ceiling as well? I dont mind spending the money on material if it will make it easier or do a better job.
Thanks Wayne
Thanks Wayne
IA
08-11-05, 05:59 AM
When taping an inside corner, it may be easier to mud one wall and let it dry before mudding the other wall if you are using an ordinary tapping knife.
If you mud both walls simumtaneously it may be a good idea to buy an inside corner knife to form the corner.
