Angle Joints
Angle Joints
Finishing the gyproc joints in my basement, I have by the stairs two wall joints which are forming an interior angle of 135 deg each. On the other side of these joints the corners are also 135 deg but they are making an exterior angle. How do you make the joints straight on angle other than 90 deg? Thank you
go buy a product called "no coat" It is a plastic reinforced paper faced bead that can go at any angle. You have to bed it in all purpose mud, not light weight. Probably have to get it at a drywall supply store.
