Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Sheetrock on walls - can it be hung vertically?
Old 09-07-05, 02:30 PM
I'm getting ready to finish my garage. I have 10' walls.
Would it be ok to just prop up 10x4 sheets long-side-up? Is there anything wrong with that? The only thing I can think of is that my studs would have to be spaced very evenly or I'd end up cutting the sheets to fit.
Old 09-07-05, 02:52 PM
Drywall can be hung any which way..... The current standard is to hang it "lengthwise" (8ft horizontal X 4ft vertical). This tends to give less joints and taping when finished. It also makes the longest joints horizontal, which typically show up less on a finished surface. As it's a garage.... hang it which ever way is easiest and matches your wall studs the best... Either way... you're gonna end up cutting.........
Old 09-07-05, 03:51 PM
XSleeper's Avatar
All the professional drywall hangers and finishers I know would hang it horizontally, since when you hang it vertically, shadow lines become much more obvious. Since it's in a garage, maybe you don't care about that, and maybe you're not even going to finish it. You are right about the layout needing to be exact... spaced evenly and perfectly plumb and square.
Most tapers would rather tape a horizontal joint at 4ft and 8ft (on stilts) than reach 10ft high, and tape a vertical joint all the way to the floor.
The only thing it saves is a few butt joints. You can search the forums here and find this same question in past threads and read the other opinions.
Old 09-07-05, 05:46 PM
IMO it is easier to both hang and tape/finish when rock is hung horizontally. As mentioned above it is easier to get a good looking job that way too. Although you may not care how it looks, if you ever decide to sell the prospective buyers might. Just something to think about
Old 09-08-05, 08:45 AM
Thanks guys, I'll just hang it horizontally.
