Removal of painted popcorn ceilings
Old 10-03-05, 11:01 AM
RaeNZ
Angry Removal of painted popcorn ceilings
My house was built in the late 80's (no asbestos) and has popcorn ceilings in disrepair. Some rooms have been pained over at least once so the water is not soaking in. I have tried to get through the paint layer to scrape, but I seem to be doing a good job of scraping into the drywall underneath. any tips on how to remove the painted popcorn?
Also, the hallway is much easier to remove, except on seams and edges where joint compount has been used - do I just need to sand that smooth at the end?
Any help would be appreciated - everything else I have read relates to unpainted popcorn - and is ineffective in my case.
Thanks
Rae
Old 10-03-05, 04:47 PM
As you have found out it is harder to remove painted popcorn. If it only has 1 coat of cheap latex paint water will often penatrate the paint with persistence. More than likely you will need to scrape the ceiling [try not to damage the rock] and then skim coat it with joint compound - it might require 2 coats. A lot of hard work but the end result will be worth it.
Old 10-10-05, 12:38 PM
rdhamm's Avatar
If you damage the drywall paper...
Seal the areas without paper with BIN or KILZ prior to the skim coat.
I heard that without the paper, the moisture in the mud will absorb into the rock and cause cracks or shrinkage in that area.
By sealing the damaged area, you can prevent that.
I don't know how accurate this information is...
Old 10-10-05, 02:06 PM
Sometimes you can get away with mudding unprimed bare gypsum, other times you can't. Priming first garruntees no problems - cheap insurance
