Low ceiling, how to protect heads?
marrjam's Avatar
10-11-05, 08:42 PM   #1
marrjam
Greetings,
I'm drywalling a basement that has a steel I-beam. I've drywalled in the I-beam that is the at the entryway to the basement. The clearance is about 6'3". Any suggestions on what to put on the edges to protect heads of my taller friends and also protect the edges? I was thinking of foam pipe insulation, but the grey foam would look kind of tacky. Suggestions please!
Thanks, Mark
thezster's Avatar
10-11-05, 08:57 PM   #2
The best and proper way is to raise the beam to a code compliant height.
Doug Aleshire's Avatar
AZ
10-11-05, 09:12 PM   #3
marrjam,
This isn't to Code and you obviously didn't obtain a permit to do this.
You need at least 6'-8".
I would recommend altering the I beam/adding a short one - seek an engineer to advise on what you can do. I have done this on occassion and it works out great. You may have to add 2 posts but this can usually be worked into most room arrangements.
I would spend the money to protect others as well as myself from getting beaned! Think about resale in what you are doing as well.
Good Luck!
Last edited by Doug Aleshire; 10-11-05 at 09:31 PM. Reason: Prior Post was edited giving better advise
bradleyfitz's Avatar
10-12-05, 06:29 AM   #4
I wouldn't bother adding foam around the edges or anything ... most people 6' 3" and up (I'm 6'6") get used to ducking around things in basements. Trust me, we don't blindly walk into low hanging obstacles (normally, at any rate).
Last edited by Doug Aleshire; 10-12-05 at 06:55 AM. Reason: Need to provide proper advice and Code Compliant
