Wallpaper down, Now What??!!
meo's Avatar
10-20-05, 12:24 PM   #1
Ok, so all the wallpaper is down (that stuff should be ILLEGAL!!!) and some of the drywall coating has come off with the glue (ILLEGAL, I SAY!!!) -- my DH suggested removing all of the "bits" that are stuck on there where some paper backing of the wallpaper is left, and then priming with a thick primer to fill in the spots that are...spotted...or whatever you'd call it -- uneven. Is there a good thick primer I should use, or two coats, or do I need to sand down the uneven spots? The spots are uneven by a hair -- but you'd notice it if you just went ahead and painted without any prep...also, there are some small gaps where the seams were -- also about a hair's depth...or I guess we could always spackle those sections? I dunno how to proceed...
bigmtk's Avatar
VA
10-20-05, 12:42 PM   #2
Spray whats left of the wallpaper backing with warm water, it should come off with relative ease. Repair any defects in the walls with drywall mud, then sand off fixed spots and lightly sand the entire wall to remove any remaining wallpaper paste.
Prime, then touch up any spots that need to be fixed with drywall mud. sand off fixed spots then spot prime. apply 2 coats of paint of your choice.
joneq's Avatar
10-20-05, 05:36 PM   #3
Every thing sounds good, but I would spot prime the areas where the drywall paper is missing with some BINbefore I patched them.The paper[edges] could start to bubble and cause more probs. The Bin seals it so the water in the mud has no effect. Wait till it's dry to use the Bin.
trinity082482's Avatar
10-20-05, 08:34 PM   #4
trinity082482
I agree Wall paper SHOULD be ILLEGAL... But on the other hand it is the glue that holds up my plaster walls, so it has purpose after all! HAHAHA
marksr's Avatar
TN
10-21-05, 08:40 AM   #5
Wallpaper hung on properly prepared walls, usually can be removed with no major problems. Unfortunately this is not always the case. I have stripped wallpaper that came off so well I believe you could roll it up and hang it on another job, and others that you had to fight for every square inch [and wish you had never seen the job]
Sizing a well painted wall does wonders for paper removal at a later date
retired painter/contractor avid DIYer
meo's Avatar
10-24-05, 03:31 PM   #6
So what is this sizing I keep hearing about??!
joneq's Avatar
10-24-05, 03:35 PM   #7
take a look at the products on this page.
http://www.zinsser.com/subcat.asp?CategoryID=2
marksr's Avatar
TN
10-24-05, 04:36 PM   #8
Posted By: meo So what is this sizing I keep hearing about??!
Sizing is a type of primer that aids both in the hanging and removal of wallpaper. IMO it works best when the wall is already painted. I have had problems stripping wallpaper off of sheetrock that only had sizing for a primer.
A_unique_name's Avatar
MO
10-25-05, 01:53 PM   #9
Another wall paper fan I see.
I agree with the sizing comments it makes a world of difference. My wife WAS a big fan of wallpaper until I made her scrape the paper off one wall while I did other projects. Many many times she asked if we couldn't just hire someone and I kept insisting NO you need to finish it. After that she won't even walk down an isle in the store with wallpaper on it so mission accomplished...LOL
