Ceiling tiles got wet and are loose and bowed
katiefran's Avatar
IL
10-25-05, 08:17 AM   #1
1.)My ceilings got wet and loosened about four to six, 12 inch square ceiling tiles that were attached directly to ceiling. Can I use some type of screw and washer to re-attach them by pulling them up, or do I need to cut them out and replace. They are the real light (cardboard?) type tiles.
2.)Also another drywall ceiling had a previous really bad plaster job. It was painted over and never even sanded. Can I sand it now over the paint to make it look better?
3.) And it has a tape seam coming loose. How can I repair it?
Thanks for any help and advice.
marksr's Avatar
TN
10-25-05, 09:10 AM   #2
Other than painting them I don't know much about the ceiling tiles.
You can sand over painted plaster/joint compound but it is a lot harder with the paint on it. It may be easier to skim coat over the bad areas. [sand first so the joint compound will adhere better]
To repair loose tape you will need to cut out the loose and retape. Apply joint compound, then tape and using a broad knife smooth out and remove excess mud. Let dry and apply more mud until smooth.
retired painter/contractor avid DIYer
katiefran's Avatar
IL
10-26-05, 05:46 PM   #3
Thank You MarkSr. I will do it as you said. Can anyone help with the ceiling tiles??
trinity082482's Avatar
10-27-05, 08:43 AM   #4
trinity082482
You can replace them. They can get expensive.. I have them too and I am getting rid of mine. UCK!
