What kind of wall around the bathtub
dufferin's Avatar
10-29-05, 04:41 PM   #1
dufferin
Hi all of you,
newbie on this forum,
I am doing some reno in a mini home and I have to redo the wall in the bathroom. I do not want to install drywall or plastic and I would like to know wath kind of wall could I use.
Thank you for your help...
d
mchar's Avatar
10-30-05, 08:34 AM   #2
mchar
Use the 1/2" Wonderboard or Durock then. If you want a smooth wall, skim coat the walls, sand, prime, paint. Don't forget - green drywall is ok for bathroom walls.
Mark
dufferin's Avatar
10-30-05, 08:59 AM   #3
dufferin
thank you,
I did not ever eard about green drywall.
Weez's Avatar
KS
10-31-05, 02:14 PM   #4
Posted By: dufferin thank you,
Check it out at Lowes, it's described as "moisture resistant" and is a tad more expensive than standard half-inch rock.
thezster's Avatar
11-01-05, 05:47 AM   #5
If you don't want drywall because of it's appearance, then greenboard isn't for you. It looks exactly like drywall because it is drywall with a water "resistant" coating.
What "look" are you going for?
