Hanging Guitars On Wall
i been usen a electronic stud finder machine
to hang my guitars on my wall but 1ft from the celling its all hallow
so is there a way to find a wood stud rather then sheet rock nails all the time
I don't know how it can be hollow at 1 foot, as the studs should go to the ceiling.
If you found a drywall nail/screw, you found a stud because that is what they are nailed/screwed into.
You can tap on the wall and keep tapping as you move your hand sideways across the wall. The tone will change when you are on top of the stud. (The tone will rise when you are on a stud, as well, it won't sound hollow.)
I hope this helps.
I hope this helps.
