Ceiling Tape Separating
skokotan's Avatar
11-21-05, 10:29 AM   #1
skokotan
In several places through out the home the tape on the seam of the cathedral ceiling is separating from the sheet rock. The longest stretch is around 2 feet. Is there any quick repair for this or do I need to cut the old out and replace it?
Thanks.
MudSlinger's Avatar
PA
11-22-05, 01:50 AM   #2
You need to cut out the old and replace it. Coating over flapping tape will only make joint coumpound coated flapping tape.
If you use flex-tape and easy-sand it will be a lot stronger.
I hope this helps.
