quick question, crown molding how high off the ground should I mount it?
C&S Rodriguez's Avatar
01-04-06, 12:52 PM   #1
C&S Rodriguez
I'm putting in crown molding along the lower edge's of the wall, should I do it before or after the carpet/laminate is put into place or if before how high do I place it on the wall?
majakdragon's Avatar
01-04-06, 01:08 PM   #2
I think you are referring to baseboard molding. Crown molding goes up against the ceiling and wall. 3/8 to 1/2" is the usual gap depending on how thick your carpet or flooring material is. You may want to ask the flooring company or installer. Good luck.
01-04-06, 02:11 PM   #3
C&S Rodriguez
Posted By: majakdragon I think you are referring to baseboard molding. Crown molding goes up against the ceiling and wall. 3/8 to 1/2" is the usual gap depending on how thick your carpet or flooring material is. You may want to ask the flooring company or installer. Good luck.
Thank you!
Peladu's Avatar
01-04-06, 11:31 PM   #4
I stay at 1/2'' every time and have never had a complaint from any carpet installers or customers.
