Drywall on the ceiling.
regnell's Avatar
01-09-06, 09:12 PM   #1
regnell
Is it OK to put drywall over a ceiling that has 1" panels, if they are all in tact and the wood is good underneath? The panels are made from some type of fibrous material that has been compressed.
marksr's Avatar
TN
01-10-06, 07:01 AM   #2
Drywall can normally be hung over most surfaces providing it will lay flat and can be secured to the framing.
retired painter/contractor avid DIYer
MudSlinger's Avatar
PA
01-14-06, 05:25 AM   #3
Ditto.
Use adhesive and the proper length screws.
My .02
Peladu's Avatar
01-14-06, 09:48 AM   #4
I agree on the condition that you take some time and either refasten the wood you are going to laminate, or you use longer screws to catch the studs/joists.
Who's Avatar
CAL
01-18-06, 10:24 AM   #5
My only worry would be how well are those panels attached?
marksr's Avatar
TN
01-18-06, 05:15 PM   #6
Sheetrock should not be attached to the panels but using long enough screws to attach it to the framing above.
MudSlinger's Avatar
PA
01-19-06, 02:38 AM   #7
Ditto Marksr!
