Outside corner on dormer
martin_30's Avatar
PA
01-16-06, 06:41 PM   #1
We are taping and mudding the second floor of our cape cod home. Where the dormer meets the main roof it cause about a 60 degree angle. Corner bead obviously will not work - does anyone have a suggestion on how to do this angle and it be a strong corner?
Thanks!
MudSlinger's Avatar
PA
01-17-06, 02:48 AM   #2
Trim-tex makes bead for non 90 degree angles. You can usually find it at "commercial" drywall places.
You could also try something called Flex-Tape, which is a stiff plastic tape that can meet virtually any angle.
If you decide to use flex tape though, I would recommend "loading" the corner using a setting type compound, followed by coating with the same; as it is an outside corner and you will need firm support behind it so it doesn't "pop" if it gets hit.
I hope this helps.
martin_30's Avatar
PA
01-17-06, 05:54 AM   #3
Thanks! I will look into those products.
