Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Tiling on top of cement board -- which side?
Old 02-27-06, 04:51 PM
I am renovating my bathroom, using cement board (Durock) on the bathroom walls that will be tiled. Which side should face out (to put the tile on), the smooth or the rough? Is it different if I use mastic vs thinset?
Thanks.
Old 02-28-06, 02:36 AM
I would put the tiles on the smooth side. If it has a factory edge, put that toward the room, as it will be easier to tape/fill the seams. (Use mesh tape for that)
I hope this helps.
Old 02-28-06, 08:29 AM
Thinset vs Mastic
Thank you for the reply.
Would you put them on the smooth side regardless of whether you are using thinset or mastic?
Old 03-01-06, 02:31 AM
I would...
(that was a short reply, wasn't it? )
MudSlinger
