knock down ceiling removal
Old 03-07-06, 07:01 PM
Question knock down ceiling removal
I've got a knock down ceiling in my home and would like a flat ceiling. Can this be removed the same way that a popcorn ceiling can? Or does it need to be skim coated in order to get a flat result? All the info out there seems to be on popcorn ceiling removal...........but my understanding is that they are different materials. Any insight?
thanx, jt
Old 03-07-06, 07:10 PM
It would be very difficult to scrape off the knock down - and you would still need to skim coat it.
It shouldn't be too hard to skim coat the texsture, you may find it easier to skim managable size squares [like a checker board] as you go back to fill the undone squares the adjoining mud should already be dry.
Old 03-07-06, 07:58 PM
should i use watered down joint compound?
Old 03-08-06, 05:55 AM
Thinning a mixing well will make the mud apply easier - just don't get carried away with the water
