Painting over two existing colors
Old 04-04-06, 08:04 AM
My new, previously owned, home has some rooms with two colors on the same wall. The bottom is a medium green and the top is a pale yellow. I have painted the room with three coats of primer and can still make out a small color differnece. Do I just keep priming until every thing is perfect or will the finish coat be best?
Also, there was a chair rail that I removed. It was glued on with Liquid nails and so there was a good amount of dry wall repair I had to do. The probmlem is that I can still make out the Joint compound I used to repair it with. (It's quite flush it just seems to shine through the primer.
Any advice would be appreciated.
Old 04-04-06, 08:36 AM
You're ok. In fact, you've probably worked too hard - one coat of primer is usually sufficient. What you didn't know was that primer is not meant to hide what's underneath, that's what the paint does. The primer provides a surface to which the paint will adhere evenly and well and it also seals the surface so nothing bleeds through your paint.
Old 04-04-06, 09:37 AM
Only stain hiding primers are formulated for coverage. usually 1 coat of primer and 2 coats of finish will cover and wear better than 2 primer, 1 finish.
Old 04-05-06, 01:02 PM
Thanks! I was getting a bit worried there. FYI: the primer was made with covering up stains in mind. I plan to go with a rather light color (it's a nursery for my first child) and wanted to make sure nothing bled through.
Old 04-06-06, 06:32 PM
Don't worry, everybody is going to look at the baby and could care less what you did to the room.
I know it's not what a Father to be wants to hear, but I speak from experience!
Mudslinger- Father of two.
Trackbacks are On
Pingbacks are On
Refbacks are On
