Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
What to put under plastered ceiling in bathroom
Old 05-13-06, 04:20 PM
The bathroom I am redoing has a plastered ceiling. There is an unheated attic/crawl space above it with faced insulation between the joists. The plastered ceiling does not have a good finish, so I thought I would cover it with green board.
Question 1: Would the green board create a problem with moisture being trapped between the board, the plastered ceiling and/or the insulation? Would plain sheet rock be better? [I'll be using green board on the untiled bathroom walls.] If neither is recommended, what should I do? I am very sensitive to mildew.
Question 2: Someone on the forum mentioned that green board does not pass inspection in some areas. Why so? Is NJ one of these areas?
Old 05-16-06, 06:07 AM
coops28's Avatar
Your not supposed to put greenboard on the ceiling with 16" oc because of sagging. 12" on center joists are fine. but since your are laminating over plaster you will be fine. Use a lot of glue and long screws. Don't worry about moisture build up.
