07-04-06, 06:02 PM
Joint compound looks like yogurt with whey?
Good evening,
Can anyone please tell me if DAP ready-mix wall joint compound that looks like plain yogurt with lots of yellowish clear liquid separated from it is okay to use? All (both) previous buckets of this joint compound I have used looked like a whitish paste when the bucket was opened. There was no liquid separated from the paste. Thank you.
Sincerely,
MerryB
Sincerely,
MerryB
TN
07-04-06, 07:35 PM
As long as it mixes ok it should be fine to use. It isn't uncommon for the liquid to seperate from the body. If you have a drill and paddle that is the best way to mix it. Otherwise scoop some mud in your pan, pour in a little of the liquid and mix with your knife.
retired painter/contractor
