Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Sagging, underconstructed ceiling repair
Old 09-19-06, 05:06 AM
Unhappy Sagging, underconstructed ceiling repair
I have a single level brick ranch with a 22'x11' addition. The addition had fiberboard walls and paper tile ceiling, which I undertook this week to update with drywall. I was shocked when I ripped out the tiles to discover that the ceiling joists are 2"x4"x12's running the length of the room (22') with a 24" o.c. spacing and mated together in the middle of the room with 1/2" plywood. Needless to say, there is quite a sag in the middle of the room. My two questions are: 1) What do I need to do to support 5/8" drywall, and 2) What is the best way to go about it? Thanks for any advice you can give!
-Dan
Old 09-19-06, 08:16 AM
Dan - Are you sure that your house doesn't have a trussed roof system? They are typically made from 2X4s spaced 24" OC. The piece of plywood in the middle on a truss system is a nailer for attaching the truss chords.
How much is your ceiling sagging and have you considered using 1/2" sheetrock. I don't see any need for the additional weight of 5/8".
Old 09-19-06, 09:06 AM
Trussed roof
Wayne,
I think you're right. I never bothered to look above the insulation. The center of the room is bowed about 1" below the ceiling around the edges, so how can I level it? I would guess that the settling foundation has caused the entire roof truss structure to settle as well.
Thanks for your help,
Dan
