Sheetrock problems
KatLouise's Avatar
10-16-06, 09:15 AM   #1
Sheetrock problems
I am remodeling my bathroom and scrapped off the popcorn ceiling, I found small holes in the ceiling, in the sheetrock, I am not for sure what this means. I looks like water damage but I can not really tell. Looks like ant tracks to be honest. Can someone help with how I should fix this.
marksr's Avatar
TN
10-16-06, 10:44 AM   #2
Welcome to the forums
Water damage usually leaves a stain. As long as the drywall is solid you can patch the holes. Small holes [1/4" or less] can be directly plugged with joint compound. Anything bigger should be covered with drywall tape - basically you surround the hole with j/c and then press in a piece of drywall tape [paper] and smooth it out with a broad knife. Add more mud when dry, sand as needed.
retired painter/contractor avid DIYer
thezster's Avatar
10-16-06, 05:45 PM   #3
Press "on" a piece of tape - don't try to push it into the hole....
It's what Marksr meant to say - I just wanted to make sure it was clear to a novice.
marksr's Avatar
TN
10-17-06, 06:05 AM   #4
thanks Zster - I guess I could have worded it better
