Wall Angles for drop ceiling
Old 10-26-06, 10:13 AM
Hello, I am about to attempt the install of a drop ceiling in my finished basement. I am using the armstrong parts and am ready to start nailing the wall angles. Hopefully this is a simple question:
When it says to nail the wall angles up, what type of nails should I use? The wall angles are metal, do you think a finish nailer or brad nailer would work or should I get a different type of nails and manually nail them in? Or should I screw them?
Thanks.
Old 10-26-06, 10:23 AM
Wall angle
Do not use a finish nailer. The nail heads are not large enough.
A long roofing nail or a pan head screw should work. Hit the studs with the nails or screws.
Old 10-26-06, 10:55 AM
XSleeper's Avatar
I use 5d nails, but screws would also work. #8 x 1 1/2 sheetmetal screws would be a good choice. Self tappers might be even better to start the hole.
Old 10-26-06, 01:10 PM
Great....I'm glad I asked. Thank you.
