expando help
Old 11-01-06, 06:10 AM
expando help
hello..i'm a newbie with a question.i have a mobile home with an expando. does anybody know how this thing works to get it back in.i'm 99% sure it is a slider not a tip in. thank you
Old 11-01-06, 06:36 AM
Welcome to the forums
While I've been in several MH with the slide out addition, I've never worked on one. Have you tried calling any of the MH dealers in your area? Maybe the MH manufacture web site?
Sorry I can't be of better help
Old 11-01-06, 11:05 AM
expando problem
talk to a couple dealers,but all they want to do is sell you a new one.
Old 11-01-06, 11:56 AM
Maybe this site http://www.mobilehomerepair.com/ will be able to help you.
Old 11-27-06, 05:49 PM
Expando or Tip Out
A Tip Out has a slant roof (so that it can TIP out).
An Expando (ie Roll Out or Slide Out - depending on what part of the country you are from) will have a flat roof.
What ever, they both will be detached by removing both interior panneling or drywall at the points of the addition and the exterior flashing around the addition (which may require the removal of roof coating). At that point remove all fasteners.
If it is a Tip Out. In both cases there will be a hinge where the floor of the addition where it meets the main unit floor. Lift from the outside with at least two people on the inside, and TIP in.
If this is an Expando you will need to remove the sideing on the lower part of the exterior as the floor of the expando is seperate from the rest of the addition and is bolted thru the bottom plate. Next check for electrical jumpers from the main unit to the addition, remove at outlet as required. If there is a built in hutch of devider, it may require full or partial removal.
From the exterior Carefully with a crowbar seperate the Expando unit from the floor. Installing several peices of 1/2 inch pipe x 6" will become rollers to push the room into the main body. Next push the addition into the main body.
the floor then tips up to fill most of the hole for transport.
Brace with several 2x4s and cover with plastic.
Good Luck!
