Corner Bead
Old 12-20-06, 09:50 AM
Corner Bead
I need to replace the outer corner beads in my kitchen area. When I moved in they were all dented and the wall is crumbling. I read the article, http://www.doityourself.com/stry/fixingcrumplecorners, at this website. It says, "Metal corner bead is sold in 8-ft. lengths that cost about $2 each." I can't find anything under $100. Am I looking for the wrong thing? Please help
Old 12-20-06, 09:53 AM
Welcome to the forums
Where are you looking? If it is indeed corner bead it most be gross price and not individual pieces.
All the big box stores should have individual pieces of corner bead in stock. Last I bought was under $2
Old 12-20-06, 11:37 AM
Corner Bead
I bet you're right! I'm not sure what the best thing to do is. I've stripped the wallpaper in my kitchen and wanted to go back with a faux painting technique. But most of my corners are dented and the joint compound just crumbles off. I'm not sure if I should just try to fill in with joint compound and hope it holds, or pull off all of the corner beads and try to replace them. It looks as though the existing beads were crimped. I'm wondering if that's part of the problem. I just don't want to spend lots of time & $ doing a faux technique that crumbles if someone bumps the wall in passing. I'd like to make the best possible repair. I appreciate your help!
Old 12-20-06, 11:54 AM
mattison's Avatar
If your corners are not totally destroyed I would go ahead and do your painting and buy some nice decorative corner gaurds.
Old 12-20-06, 03:57 PM
it is no little job to remove and replace the corner bead - they are usually finished with 3 coats of joint compound.
Corner bead is crimped or nailed in place. IMO nailing is better. If it is loose you can renail it to the stud. It would be best to remove most of the crumbly j/c and remud. Unless the corner bead edge is beat to pieces floating a nice coat of mud on each side will make it look new.
Old 12-20-06, 04:19 PM
Thanks for all of your help. I'm going to take both of your advice. I'll remud, paint, and put a corner guard on each corner. Hopefully that'll take care of it. I appreciate your recommendations!!
Old 12-20-06, 04:22 PM
One last question...
The metal is exposed at the outermost part of the bead. I can't seem to cover it competely with mud. Do I just paint over it, or do I need to cover it somehow? Thanks!
Old 12-20-06, 04:29 PM
The very edge of the metal is supposed to be exposed [just painted] When you mud the sides you tightly run your knife on the metal edge which insures you have a straight line/corner. it is also more durable not to have mud on the very edge.
Old 12-20-06, 08:18 PM
Great! That's what i needed to know. Thanks!
