Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page > compound preferred for splatter texture
Old 12-30-06, 01:44 PM
Hey,
What would you guys prefer to use lightweight joint compound or plain joint compound for a splatter texture? Local SW store doesn't know of any differences. Thanks
Old 12-31-06, 04:09 AM
chandler's Avatar
There's not much difference in that application. Do you plan on knocking down the texture? If so, either will be fine.
Old 12-31-06, 04:26 AM
I use which ever one is handy, never noticed any difference.
Old 12-31-06, 11:11 AM
chandler's Avatar
You're right. 5 gallons of one seems to weigh about the same as 5 gallons of the other. Where does the "lightweight" come into play? They're both heavy!
Old 12-31-06, 11:22 AM
Larry, your'e right, they're both heavy. The only light drywall buckets I've ever picked up are the empty ones If a wimp had to carry 5 gal buckets of mud on a regular basis - he wouldn't be a wimp for long
I think the lightweight is so called because it's a little easier to sand. It also isn't supposed to be good for tape and bed coat although I have done so in a pinch. As for texture, I don't think it makes much difference.
Old 12-31-06, 04:03 PM
XSleeper's Avatar
Lightweight mud in the blue buckets will shrink back a little more than the regular mud will. A lot of times using the lightweight mud will result in a smoother, more rounded texture on ceilings.
Generally, though, most contractors use the green buckets- the regular mud- and thin it with water. Remove some mud from the 5 gallon bucket and start by adding 64 oz of water, and mix it well with a paddle. It's hard to describe how much it should be thinned, but it has to be runny enough to splatter on the wall- kinda like pancake batter. If the globs are too big when it's sprayed, its probably too thick. Add more water until you get the consistancy you want.
Trackbacks are On
Pingbacks are On
Refbacks are On
