Ceiling in bad shape
Old 01-04-07, 05:37 AM
We are remodeling our bathroom and currently need to re-texture and paint the ceiling.
Part of the the ceiling is rather rough due to us tearing down a huge cabinet that hung from the ceiling.
I've patched it as much as I could, but I think I need a heavy texture applied to cover up any flaws. Is there a good texture available that I can apply myself? I don't think the stuff you add to your paint is thick enough.
thanks,
Hillary
Old 01-04-07, 06:03 AM
Personally I don't like much texture on a bath ceiling. A textured ceiling has more surface area than the same size ceiling that is slick. More surface area means there is more area for steam to hang onto which means a greater chance of moisture damage.
IMO it would be best to skim coat the ceiling. It isn't hard to do. If skim coating the ceiling is overwhelming to you, break it up into little squares like a checkboard. Skim all the 'black' squares, when dry skim the 'white' ones. Sand when finished.
You can buy texture paint that should be sufficent to hide the repair - paint the whole ceiling with it. Texture will hide minor defects but it won't make a bad patch job disappear.
