1/4" Drywall question...
Old 01-09-07, 05:08 AM
I assume this is the stuff to use for arched entryways? Also, I'm guessing it could be used for a flat basement cieling to conserve headspace?
Old 01-09-07, 05:38 AM
Forget about using it for a ceiling.
It will sag and you don't save enough headroom to make a difference (only 1/4 to 3/8").
Dick
Old 01-09-07, 05:39 AM
It can also be used to cover damaged plaster/drywall.
Old 01-09-07, 05:40 AM
It can also be used to cover damaged plaster/drywall. I wouldn't use it alone on a ceiling. It only saves 1/4" height and it will probably sag over time.
Old 01-09-07, 05:53 AM
Sagging, yeah that makes sense. But is it what is used for making an arched entryway?
Thanks!
Old 01-09-07, 06:10 AM
Yes you can use it on the arch. 1/4" drywalls 2 main uses are to overlay an existing wall or use on a radius as it bends better than the thicker drywall.
