drywall repair
Old 01-17-07, 02:11 PM
drywall repair
As a result of a leak around a stove pipe (since repaired) I have half a dozen spots from 1 to 5 inches in diameter where the drywall paper has cracked. Do I need to put tape over the exposed drywall (gypsum?) or can I just apply joint compound?
Old 01-17-07, 03:25 PM
Welcome to the diy forums
Pull/cut off any loose paper and then seal with a solvent based primer. It will then be ready to apply j/c.
Old 01-19-07, 02:33 PM
Thanks, i'll give it a try.
Jim
