Just removed paneling. What do I do?
Received 0 Votes
Just bought a house and removed some paneling. Behind I found Furring strips (don't know if that is the right spelling) They were nailed through drywall that was covered with wallpaper. What are my options?
Received 0 Votes
no wallpaper or paneling!!
My wife wants to paint. Which is more economical? Nailing drywall straight to the strips which are probably nailed straight into studs or removing the strips and patching the holes?
Received 0 Votes
If by economical you mean money or labor, then patching is the answer. Costs less to remove stuff than to add it and takes less time too. Of course it depends on how hard the wallpaper will be to remove, your abilities in regards to spackling, and the level of perfection you (or your wife) will accept. A patched wall is always a patched wall but a new surface is a blank canvas on which to work.
Received 0 Votes
wallpaper is very old and elastic.
The wallpaper has an elastic feel and is easy to pull off. On Wednesday my brother is coming over to take a look and give me his opinion. We just bought this house so money is an issue. We have two more months on our lease in our apartment so we have time, Thanks for the advice
Received 0 Votes
First (and easiest and cheapest option): remove the furring strips and remove the wallpaper. Then prime and repair the walls. Prime again and then topcoat.
Second option: Remove the furring strips then cover with new 1/4 inch drywall, prime and paint.
