Noisy condo
mah1t1's Avatar
05-05-07, 05:11 AM   #1
Noisy condo
I just moved into a new condo and it's noisier than I expected. The association bylaws prohibit owners from doing anything to the drywall other than painting it. Is there any product available that can be applied to or over the drywall to reduce the noise?
Thanks in advance for any help.
chandler's Avatar
GA
05-05-07, 06:59 AM   #2
Welcome to the forums! Sadly to say, there is nothing that can be surface applied to quieten the noise. If the condo was properly built, there should be adequate insulation between the floors and walls (even interior walls) to aid in noise reduction and heat/cold transfer. But as with all well laid plans of mice and men.......
mah1t1's Avatar
05-05-07, 10:35 AM   #3
I was afraid of that :-{ Thanks for responding!
marksr's Avatar
TN
05-05-07, 01:48 PM   #4
Not sure how well you can make it look but hanging fabrics or something that can help obsorb and block noise might help.
retired painter/contractor avid DIYer
twelvepole's Avatar
OH
05-05-07, 01:49 PM   #5
Create 'white noise' to block exterior noise. Soft music, ocean, wind, and rain sounds are often used to block disturbing noise.
