Stupid Question? Painting over plastic?
I just recently remodeled my bathroom to about 50% of the way now, the sheetrock is up and the mud is sanded with very few bumps or bruises. The outside and inside corners look better than pro and I even made two little pocket alcoves with recessed lighting for decorative items or even hand towels.
The first question/issue I am having is well, outside corners. Is my latex paint after a good primer going to stick to these outside corners? I used plastic outside corners and drywall nailed them every 6 inches on BOTH sides . I know that whenever I get to much paint on my paint caddy and accidently let it dry, I can just peel it right off of the plastic. I see finished houses and drywall with metal corner molding and can see the metal ends, I assume they just prime over it and then paint - but how does it stand up? I could have smeared some mud down along the edge but can't imagine how I would make it look like a nice outside corner without some seriously stressful and meticulous sanding?
The second problem I am having and am dealing with:
Sticky joint tape. It sucks. Not fiberglass but a joint tape that has holes all through it that you peel and stick then mud. Figured it would save me a step and before I even went to paint, I noticed hairline cracks on the walls where I couldn't as many nails as I would like as it's a horizontal and thus the distance between the studs is causing this along with this junky tape. So I sanded it down. Put little pieces of fiberglass tape in every 2 or 3 inches...mudded it , then wet my NORMAL joint tape, and smoothed it over, then mudded over. Looks great now. Just wondering if anyone has had any issues with this stuff? I also notice that the mud bubbles out of holes and is visible unless you mud heavy and sand to smooth, plus you have to feather out a bit more.
Sorry for the novel there.
Welcome to the forums!
I assume what you are concerned about on the outside corners is the little bit of corner bead that shows - paint should stick well, actually a little better than the j/c. it is a common problem for paint to chip off of the corner bead when hit.
Mesh tape is basically a good idea that just didn't pan out. Paper tape always does a better job. About the only time a pro will use sticky tape is on a repair where time is critical and using hot mud over the tape. Setting compounds like durabond help to avoid the problems associated with sticky tape.
Wow thanks for the quick reply. I'm waiting for a few patches to dry so I can sand and prime and get this project done before xmas. I still have the flooring, crown molding, toilet & vanity to put in and of course the accessories.
Glad to know, I researched and couldn't find anything. Talked to a guy at the big orange home imp store and they said to just run my tool out far enough to leave a layer of spackle...
:l
As for anyone dinging the corner, that wont be a problem as I will have a lock and key on this bathroom. I'm thinking of just never using it and leaving it as a museum.
After 3 bathrooms, I can't wait to finish the rest of the house. Bathrooms and kitchens take forever with all of the little stuff you have to do. I also basically had to remove half of the studs and replace them with STRAIGHT pieces. The doorways from one segment to another were so far off it looked like a drunk framed this bathroom.
Satisfaction level is kicking in, but now because of the size of mirror and med cabinet I built for it, I had to go with recessed lighting. I only have two over the vanity and it's a bit dark now. Not to mention, I am painting that wall with dark chocolate and the rest of the bathroom chocolate. Looks good with the granite top and the stainless fixtures etc. But I think I may have to put something else in that might look like an afterthought DOH At least I have access to the attic above to do this though.
Anyway thanks. I appreciate the help.
:l
