recess shelves
Old 11-25-00, 04:52 PM
Question
I'd like to put some recess shelving in my hall walls. How do you construct the "cubby holes"?
Old 11-29-00, 02:10 AM
cubby holes
Cut out the drywall between the studs the height you wish. Nail blocking to the studs below & above the opening the depth of material you are planning to line the niche with. The spacing between the studs if they are 16" centers will be 14 1/2". The depth will be 4" to 6" depending on the wall.
Old 12-01-00, 05:41 AM
Before you start punching out board, I suggest you find out where any electrical or mechanical service is with respect to the wall you are considering.
