Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Temporary load bearing wall (do I need to remove the drywall ?)
Old 03-14-08, 06:57 PM
G
Hello,
I am in the process of partially removing a load bearing wall and I was planning on installing a temporary wall.
I was wondering if this wall needs to be connected to the beams overhead or if can keep the drywall in place and simply put a 2x6 on the ceiling to have the weight distributed on 2x4s and another 2x6 on the floor.
The wall is installed on the first floor of a bungalow. Above is only the attic. Bellow there is flooring plus a a 8x8 beam going the length of the house.
Any help would be appreciated.
Thanks.
Old 03-15-08, 04:49 AM
W
Received 34 Votes on 31 Posts
Load Bearing Wall
If this is an interior wall, you will need two temporary walls, one in each of the two adjacent rooms.
Old 03-15-08, 09:28 AM
G
Good point ... yes I will put up 2 temporary walls ... one on each side.
But do I need to remove the drywall on the ceiling to put the temporary walls in place ? ...
Thanks.
Old 03-15-08, 09:59 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Gab
The ones I've seen (many)/done (one), just screw thru the 2x into the joists to hold it then drive the 2x upright at the bottom. You may still have a little damage to repair, but I don't think you need to remove the sheetrock on the ceiling.
Old 03-17-08, 04:42 PM
G
Thank you all for the tips.
Old 03-18-08, 09:32 AM
V
I usually put some cardboard between the temporary wall and the ceiling/floor(unless it's carpet) to avoid any additional scrapes.
