stipple walls with panda paw
If anyone has any suggestions for stippling a wall with damaged sheetrock from stripping wallpaper (incorrectly hung) I could use advice. I have floated and skimmed the walls but still need a light texture to hide imperfections. I bought a panda paw stipple brush and it seems to work with thinned mud but haven't painted yet so result is questionable. Will this be ok or should I use another method.
Welcome to the forums! As long as you can live with the sticky points on the wall and the Panda didn't mind, then it should be ok. I prefer to use a knock down finish as opposed to stippling on walls if necessary to help hide boogers. It leaves an almost smooth finish with a little texture without the points.
