Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Tool for drilling hole in center block/cement walls?
Old 10-23-08, 02:43 PM
Is there a tool that drills into center block, or cement walls. It looked like a large nail gun, worked the same way. Any suggestions?
Old 10-23-08, 04:12 PM
Received 59 Votes on 55 Posts
Hammer drill with a masonry bit on it.
Old 10-23-08, 05:16 PM
Received 156 Votes on 138 Posts
....and if the hole needs to be larger than a bit you can find, drill a series of holes in a circle and then hammer out the center.
btw - welcome to the forums!
Old 10-23-08, 05:30 PM
I'm not familiar with the term "center block" and am wondering if you meant "cinder block".
If that's the case you don't really need a hammer drill.A regular VSR drill with a masonry bit will handle that fine.Cinder blocks can break up if impacted heavily if you are going through the hollow parts.
If "center block" is something else like a solid cement block them yes a hammer drill might be needed.
Old 10-23-08, 06:35 PM
Speedwrench's Avatar
i think the poster was talking about a air hammer, or air chisel, but a hammer drill will work much better than a air hammer.
yes you can drill concrete blocks with a vsr but the hammer action will drill 2 to 3 times faster.
life begins when the kids leave home and the dog dies.
Old 10-23-08, 06:48 PM
The location of where you drill is important and depends on what you want to do or attach.
If it is a modern concrete block, drilling about 3" off center (lengthwise) will get you into the core, which may be hollow, so you can drill easier (only 1 1/4") and can insert something like a toggle bolt.
If you drill into the center, you may be into the center web and will have to go all the way through, but your hole will be in solid material - then you have a wide range of fasteners.
Tapping with a hammer and a good ear may give you some clues.
Masonry walls in California can be tricky because of the grouting and some of the special shapes that MAY be used. Is this just a veneer(4" thick) or a stuctural masonry wall (6" or 8")?
There is always the use of a power actuated hammer powered by a 22 caliber charge for surface mouting. It is fast and the guns and can be relatively cheap.
Dick
Old 10-23-08, 10:04 PM
Smile
Thank you to everyone who posted reply's. Yes, I probably spelled it wrong...center block...cinder block. I am researching for a family member. Give me a hammer and nails I do just fine. But anything beyond that, ouch.
Thanks again from a mom who wants to learn.
Kelli
Old 10-24-08, 04:11 PM
You're in the right place - welcome to the forums.
Old 10-28-08, 03:20 AM
I use a 1/2 hp -- 800rpm--55 year old drill .
Still works like new.
B & D would hate to hear that....................
