Name that wall material
My Boss wants me to replace the paneling that is around the sinks and cooking area of our pizzeria. I am trying to figure out what it is called, so I can price it out. I know it to be Laminate Paneling. It is very similar to a tub or shower surround. The existing material is a faux Tile look in 4X8 panels jointed by caulk and most likely glued to the wall.
I want to find out some things before I take on the project:
A: How hard is it to remove the old material, provided it was glued to; lets say, Sheetrock or luon?
B: How much does a similar product cost, whats its name, what dimensions is it sold in and how hard is it to install?
If it's what I think it is, it's a masonite panel and they are usually found where paneling is sold. As far as I know, they always come in 4x8 sheets. I haven't noticed any of them for sale in quite awhile so they might have been discontinued.
If they are glued and nailed, you probably won't know how big a deal removal will be until you start. With some luck you might be able to use a stiff broad knife and seperate the panels from the glue....... or you might have to fight for every sq ft
Sounds like masonite wallboard to me, too. Masonite is not recommended in areas where it will be exposed to moisture. It's constructed of sawmill waste and glue. When it gets wet, it swells and surface finish can buckle and spall and look unsightly and unsanitary. When it is in this condition, it is a health department violation in a restaurant kitchen.
Might want to consider FRP (Fiberglass Reinforced Panel) instead. Waterfroof, available in colors, very durable, and can be sanitized. Only available in a "pebble" finish that I know of though. About $28-30 per 4 x 8 sheet last time I looked. Trim strips for the edges and corners are about $1.20 per 8ft length.
