drywall to slump block
Old 03-01-09, 01:28 PM
V
I have finished installing new drywall and am now at the windows. The windows were set into the slump block leaving about a 6" sill inside and the drywall was in some way 'glued' to the slump block around the windows. There is insufficient room for installing a wood frame without having to install all new windows (exceeds my budget!). What would be the best way to attach the drywall to the slump block? Should I first seal the slump block?
Old 03-02-09, 04:04 AM
Received 757 Upvotes on 662 Posts
I'm not familiar with the term 'slump block'
It's never a good idea to install drywall directly to masonary. Would using plywood and casing be a better alternative?
Old 03-02-09, 05:23 AM
coops28's Avatar
You can glue it using drywall adhesive. wedge something in between to hold it while the glue dries.
Old 03-03-09, 07:52 AM
V
due to the limited thickness space between sill and window
(3/4") I was considering sealing, then gluing on 1/2" 'Hardyboard' and then gluing 1/2" drywall over that. Would that work, or is it 'overkill'?
