Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Rounded corners on a 90 degree pony wall
Old 03-11-09, 08:46 AM
W
I have a pony wall with a 90 degree corner. I plan to use rounded sheetrock corners on it. What do I do where the two vertical and the horizontal corners meet to get a rounded outside corner?
Old 03-11-09, 10:00 AM
Received 754 Upvotes on 659 Posts
Welcome to the forums!
Use a rounded corner bead. Probably not available at a big box but any drywall supply house should have it in stock.
Old 03-11-09, 02:02 PM
coops28's Avatar
You have to use an outside corner piece/knuckle. Its comes in a 3 way 90 deg. Home depot might have them. If not then go to a drywall supply house.
Put the corner piece on first then butt the other pieces into it.
