Texture problem
Old 05-26-09, 12:25 PM
P
Texture problem
Hello
I have a problem with ceiling paint. I added a new room so I had to do some drywall work - where I taped or added I had to scrape the texture from the ceiling.
In preparation for paint I put on a drywall primer from Benajamen Moore and then I sprayed texture from Synco (white).
Everywhere that there was previously old ceiling texture and where I tried to feather in the spray the ceiling has turned Yellow.
Any ideas on cause or how to fix?
Old 05-26-09, 12:50 PM
Received 785 Upvotes on 688 Posts
Welcome to the forums!
Not sure I understand
Does the new texture look yellow? or the the old looks yellow against the new?
You may have to use a solvent based primer to seal the stain.
Old 05-26-09, 12:57 PM
P
Arrow
Thanks for the suggestion ...
The problem is that where ever I have gone over the old popcorn texture ceiling with the new synco yellow bleeds through.
Where I have applied it to the new section it is white.
Old 05-26-09, 01:24 PM
There is some type of stain on the original popcorn. Might be cooking oils or nicotine. It would bleed thru latex paint/primer just like it has thru the new texture. The fix is to prime the ceiling with a solvent based [oil base would be ok] and then [when dry] apply a fresh coat of latex paint to the ceiling.
Old 05-26-09, 03:19 PM
P
Question
There is no stain visible on the old texture, looks white and still bleeds through a yellow stain and not just in spots, it seems to blee through where ever I go over old paint.
I have heard it may be latex over an oil base - does that make any sense?
Old 05-27-09, 03:44 AM
I wouldn't think latex over oil base would be the problem. The water in the texture or latex primer/paint is activating the stain causing it to turn yellow.
