Removing leak stains on a ceiling...
Old 05-28-09, 08:52 AM
N
What is the best way to do it?
Old 05-28-09, 09:24 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
You really can't remove the stains, you'll need to hide them with a stain blocker/sealer type primer. I generally use Kilz. Zinser also makes a good one. Both are available at the big box home stores.
Old 05-28-09, 10:23 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
And to add to what TG said..the latex based stain blockers aren't as good for water stains IIRC. Since the carrier/solvent in a latex is water...the stain bleeds though. Of course it somewhat depends on how bad the stain is...I have used latex Kilz on very light stains and it seemed to do ok.
You may need either an oil base or shellac based...and that can give a different sheen to the top coat of paint. Oh, and the shellac based wil have a lot of fumes. Good ventilation is a must with oil or shellac.
Old 05-28-09, 12:37 PM
Received 754 Upvotes on 659 Posts
I wouldn't use a latex primer on any water stain. Often when they do cover the stain - the stain comes back later
Oil base primers [like original kilz] will cover most stains. Stubborn stains will require a pigmented shellac sealer like zinnser's BIN.
The primer shouldn't affect the sheen of the top coat [provided the entire wall was properly sealed at some point] It will take the top coat longer to dry and settle down to the correct sheen.
Old 05-28-09, 01:38 PM
If the area is soft,crumbly,loose etc it needs repair.Do not prime or paint over an area that isn't 100% solid and intact.If possible examine the area on the other side and check for mold.
