Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Vinegar and water for removing popcorn
Old 06-01-09, 06:40 AM
C
I have searched this and the Plastering forum and not seen any posts on using a vinegar & water mixture to make it easier to remove popcorn ceilings. Has anyone been successful doing this? Is there any reason not to do it?
Check out this video. It get's really interesting at about the 1:45 point.
YouTube - Popcorn Ceiling Removal is EASY!
Edited to ask: Is there a good tool for scraping 8 ft ceilings from floor level? All that up and down on a ladder seems like a lot of work. Thanks in advance
Old 06-01-09, 06:52 AM
Received 759 Upvotes on 664 Posts
I don't know what benifit there would be in adding vinegar. Unpainted texture is water soluable. Water and elbow grease is all that's needed to remove popcorn.... that and containing and cleaning up the mess
I suppose you could gently use a floor scraper or attach a handle to your hand scraper but you will have better control with your hands closer to the work. You could use a rolling section of scaffolding......
I didn't watch the video - I'm stuck with dial up
Old 06-01-09, 10:15 AM
G
I could only sit through 1/2 that video. Put lightweight painter's plastic on your doors and walls, spray water on run this over, with or without the bags:
Homax at Lowe's: Ceiling Texture Scraper
Never used one, might work., I use a floor scraper, long handeled, with two layers of plastic on the floor, one taped down, the other loose and heavier gauge to throw away with waste texture. Be safe, G
