Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Attaching window rosette to old plaster wall
Old 06-08-09, 11:13 AM
I took down a couple of pieces of window trim in a century home to deal with counterweights. On one, the rosette pulled loose from the top trim - it had been toe-nailed into the top and side trims poorly in the past.
I was thinking about using Liquid Nails to reattach the rosette this time, then putty and paint around the edges (whole living room needs a paint job). These are old plaster and lathe walls, and it looks like the counterweight channel extends up behind at least part of the rosette - I'd prefer not to nail directly into the wall because it may be hollow, and because some of the plaster has crumbled. Toe-nailing seems like a pain and problematic.
I hope to never take down the trim again, certainly not the rosette - but is this an okay way to reattach the corner block?
Old 06-09-09, 07:26 AM
coops28's Avatar
Yes I think gluing is your best option. I wouldn't use liquid nails. It dries too slow. Loctite makes a great glue that will hold tight in 30 seconds.
Old 06-09-09, 03:28 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Coops, sorry for butting in, but is that Powergrab you are referring to? It is outstanding for quick adherance.
Old 06-09-09, 05:13 PM
Thanks for the recommendation - I'll look at their line next time I'm at Home Depot and read the intended usages - looks like the have a paneling/drywall one and an all-purpose one.
