Default Moldy Walls, Holes in Walls and Door
I'm gunna make this short since I had my post complete and then my browser crashed
1. shortly after moving I noticed there was mold forming behind my walls..How do I fix this?
2. Next! got a few holes that need fixing..whats the best way?
3. I have a hole in my wooden door that also needs fixing
htt p://img189.imageshack.us/img189/7458/img0145q.jpg (sideways)
4. The paint on my door was a bit oily so I had to take it off completely since my dog was chewing on it.. I would like to repaint it back but not sure what kind of paint to use.. it seems like they just painted over paint because there are like 2 more layers but its not peelable so i left it.
(sideways)
In my bathroom.. I'm not sure if it would be better to deal with the mold first or fix the holes first.. but still I don't know how to do either so need help there.. and as for my wooden door is there anythin i can do? maybe patch it sand down? put somethin over it to seal it b4 i paint?
(sideways)
Welcome to the forums!
You might be able to wash the mold/mildew off of the surface with a bleach/water solution. If the mold is behind the drywall, it should be replaced. Do you know what caused the mold?
Joint compound is good for repairing holes/nicks in drywall. It can also be used to repair the door.
Paints don't adhere well to oily surfaces. Once the oil is removed and the surface sanded [and dust removed] it should be ready for paint.
