filling in drywall cracks
Old 08-31-09, 11:50 AM
RoxieCs's Avatar
Ok, I had a professional come in to raise my bathroom ceiling 6". I can tape & bed so I told him to just put up the drywall. The edges are uneven and there are large cracks (1/4 - 1/2") between joints and edges. Is it better to sand down the uneven edges? And what is better to fill in the gaps - caulk or pieces of drywall glued in? Or should I just tape it and try to compensate with layers of mud.
Old 08-31-09, 03:55 PM
Received 754 Upvotes on 659 Posts
You should be able to prefill those areas - apply mud, let it dry before the tape and bed coat. If you feel that a gap is too big, insert a thin piece of drywall. 1/4" gaps are fine - I'd rather have a little gap than 2 pieces forced tightly together.
It's rarely a good idea to sand or shave down drywall. There are problems associated with applying j/c over exposed gypsum. Can you elaborate on these areas? Is it where a factory beveled edge and a cut edge are mated together? Where are these areas?
Old 08-31-09, 04:06 PM
RoxieCs's Avatar
It is a coffered type and I would like the corners and edges to be sharp and square. So you think i can just build it out where I need to to make it square, fill in any gaps and then put on my tape and mud over that?
Well I decided to just go ahead and try so I went and thinned out the JC and filled in gaps and smoothing it with a knife. It is looking good although I'll prob need to add another coat and do a good amount of sanding before I can tape. thanks!
Old 08-31-09, 04:30 PM
RoxieCs's Avatar
Yes it is where the two pieces come together a cut edge placed over a finished piece. From the ceiling the side drops down then goes back towards the lower (old) ceiling. Kind of like a Z with the center straight if that makes any sense at all.
Old 08-31-09, 04:41 PM
I'm not sure about the Z
It sounds like a factory beveled edge and cut edge were hung together. Not the best senario but it happens. he might have been trying to minimize waste. Anyway, if you prefill the low side it should tape fine.You might have to feather out the final coat a little farther - depending on how the joint can be viewed.
Old 08-31-09, 05:21 PM
RoxieCs's Avatar
ceiling photo
Here's a photo to help clarify. I was hesitant to add so much JC for fear it would crack, but I hope it'll work
Old 09-01-09, 03:22 AM
Regular ready mix joint compound will crack if it's applied too thick in one application. You can either apply multiple coats or use a settting compound like durabond to prevent cracking. From what little I can tell from the pic - there shouldn't be any problems.
There are a lot of failures associated with the 'sticky' tape you are using. Paper tape has a better track record. If you use 'sticky' tape it's best to use a setting compound over top of it. The setting compound dries harder and helps to keep the 'sticky' tape stuck to the drywall.
The outside corner where your tray ceiling starts should have corner bead installed.
Old 09-01-09, 03:38 AM
RoxieCs's Avatar
Thank you for all your help. This one's been a challenge for me. Not as easy as working on a vertical wall surface. Now I know what to do to finish it.
