Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Removing construction adhesive from wall
Old 09-12-09, 05:36 PM
L
I have removed a bulletin board in order to paint my kitchen. It was glued on with construction adhesive.
It is on painted drywall or plaster (I'm not sure which).
What would be the easiest/best way to remove the old adhesive?
Old 09-12-09, 07:01 PM
T
Received 41 Upvotes on 34 Posts
A sharp chisel. If it is plaster little damage will result. If drywall you may have a little more repair but it is not complicated nor expensive.
Old 09-12-09, 07:19 PM
L
Thanks!
I tried a putty knife and it didn't do very well, but I didn't think of a chisel.
Old 09-13-09, 04:09 AM
Received 757 Upvotes on 662 Posts
It helps for the putty knife to have a sharp edge. Sometimes scrubbing it with paint thinner will remove the adhesive but it requires a lot of elbow grease. I agree with tightcoat, scraping and then repairing the wall is usually easier/quicker.
