adhesive over cinder block wall
Old 10-07-09, 09:10 AM
L
I am looking into installing fiberglass reinforced panels in a commercial kitchen; the walls are bare cinder block = do I need to prep the block before using the adhesive for the FRP panels?
Old 10-07-09, 09:11 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Should be fine as long as its clean and dry.
Old 10-07-09, 10:02 AM
Received 754 Upvotes on 659 Posts
....but would bare cinder block suck up the adhesive causing the panels not to adhere?
Old 10-07-09, 10:12 AM
Gunguy45's Avatar
Super Moderator
Hasn't been a problem in my experience..it's more like a mastic/contact adhesive/Liquid Nail. Skins over pretty quick and the older stuff was bad on the eyes and nose. I think its all low VOC now..might be a little better.
I would recommend the trowel applied stuff over the caulk tube stuff.
LIQUID NAILS® Adhesive - Fiberglass Reinforced Plastic Panel Adhesive (low-VOC) (FRP-310)
