Help Needed
Help Needed
I am having a bathroom remodeled and to make a long story short, my new Zodiaq vanity top is approximately 1/4" too short to fit between two walls. In addition back wall is bowed a bit. Is there anything I can do to side and back walls to make vanity fit better other than having a huge bead of caulking on each side?
Without knowing more then what you have told us here, you might think about centering the vanity top so there is only about 1/8" on each end, and then put up vanity trim around it. Use a good wood and waterproof it. You did not say how big a bow was in the back wall, so it is hard to answer that part. Good Luck
